Does anyone know a way to do a void with a 3d path?
i have a concrete slab with a pipe that runs all the way thru it. at one end the pipe makes a 90 degree turn and penetrates the top of the slab.
there are also vertical pipes that extend vertically from the main pipe every 20 feet or so.
its simple enough to make the void thru the slab horizontally but the trouble is the vertical pipes that intersect the main pipe.
i have tried different types of voids/openings and they dont seem to work well together (Revit will not allow 2 voids to intersect each other).
i have come to the conclusion that the best way to accomplish what i need is to draw my slab as a sweep with a hole in it and use voids or openings for the vertical pipe penetrations, but i still wont get the proper geometry at the 90 degree elbows.......
does anyone have an easier way to accomplish this??????
thanks in advance for any help.
