For some reason in 2009 I can't place a Fascia object on the ridge line of my roofs. Anyone else experiencing this?
It has been mentioned in a couple of other posts. This is not possible in 2009 the behavior was changed. You can use an in place sweep or there are some other solutions mentioned in other posts.
I suspect this was changed because using a fascia for something like a ridge vent, while extremly handy in many cases, is not a CORRECT application of a fascia object.
Finally found that other thread.
With Revit full of other required workarounds, why has Autodesk decided to remove this one?
Instead of removing something that worked, why not add a feature for something that doesn't, like being able to add a gutter to a non-horizontal roofline. Some of the decisions that get made are truely bizzare.
Yeah, they're suppose to be eliminating work-arounds by adding features, not by removing features.
I would rather hear that the programmers themselves have no freaking clue how the feature disappeared than to hear that they're intentionally removing flexibility from existing features over some arbitrary principal of what is "correct".
