how to convert AutoCad text to be readable in Asper program.in fact i need to convert text into lines. that is for Cnc cuting of metal.
I tried to look up this ASPER program to read about
the formats it might handle, no luck.
You should be able to use DXFOUT, or simplified
HPGL as indicated here:http://usa.autodesk.com/adsk/servlet...linkID=2475323
If you post a little more about the destination application
it might be of some use.
Hi
Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section...
ID: TS18595 - Exploding text or MText objects into lines
ID: TS74403 - Exploded text is moved or relocated in Z axis
ID: TS45316 - Export text entities as usable objects with CNC and other external devices
Have a good one, Mike
