etboards17
Another question that has risen is what are the light meters able to record? In the image below you will notice that between 2 and 4 pm the light drop off is dramatic. This is making me wonder if the light simulation is not able to measure diffused light from a cloudy sky. WSSP requires that all rooms be measured with a diffused sky and I do not think MAX Design 2009 is using a diffused sky. In the settings there are a few sky models, one of which is CIE Overcast Sky. You would think that this sky model would be diffused light, but seeing the renderings progress through the day.... I have to wonder. There should not be a drop off of light between 2 and 4 pm, which makes me question the modeler completely. Seeing this effect kind of makes sense being that mental ray uses light rays to calculate its renderings. If there is not direct light in the room, then there is no light bouncing, thus resulting in low light levels, which is not at all a lighting simulation.
Any thoughts!?
