Thread: Supporting Number Pad (NumPad)
    2000-01
    Seattle WA USA
    5,859
    Lightbulb Supporting Number Pad (NumPad)
    It is possible to add support for NumPad keys in a CUI.
    For instance, you can assign an OSnap override to each of the numbers on the number pad, and use the number pad during the middle of a command to supply the override, as long as NumLock is off.
    The attached file has OSnap overrides for each of the numbers 0-9.
    0 = EndP
    1 = Mid
    2 = Cen
    3 = Nod
    4 = Qua
    5 = Int
    6 = Ins
    7 = Per
    8 = Tan
    9 = Nea
    F1 has also been redefined to be the <Escape> key instead of displaying Help.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2004-10
    Scotland
    102
    Default Re: Supporting Number Pad (NumPad)
    It would be very handy for left handed mouse users, but I prefer to use SHIFT & right-click the mouse.
    I found that users liked to retain the Number Pad for typing in numbers.
    I have some of the standard layers assigned to CTRL+NUMPAD1, 2, etc.
    Another layer of use is to assign CTRL+ALT+NUMPAD1, 2, etc. to macros.
    2004-07
    Detroit Michigan
    2,508
    I have the overides set to shift + number.
    I then use the pgp to assign commands to assign
    the modify commands to the numbers.
    I agree, the number pad can be very useful.
    It also helps to get a keyboard that has the number pad on
    the left side.
  1. numpad or speedpad as extention
    By kuruczregina in forum Hardware
    Last Post: 2023-01-19, 11:15 AM
  2. Vista is not supporting AutoCAD 2006???
    By sudhirkizhakoote in forum CAD Management - General
    Last Post: 2008-06-03, 12:33 PM
  3. AutoDesk Supporting Addons
    By vipin_nair in forum CAD Management - General
    Last Post: 2008-05-20, 12:13 PM
  4. iGesture Keyboard / NumPad
    By spencer.67965 in forum Hardware
    Last Post: 2004-12-06, 05:48 PM
