Thread: Family Parameter Organization
    2007-09
    St. Louis, MO
    188
    Default Family Parameter Organization
    Is there a way to organize your parameters, or do they only show up in the order you make them?
    Pittsburgh, PA USA
    1,906
    Default Re: Family Parameter Organization
    There have been one or two other threads on this, as well as a class on the Family editor from AU 2007 that discussed this. I don't bother, since some of them will change order later if you begin filling in say, the Assembly code in a family that several types in it.
    2007-09
    St. Louis, MO
    188
    What you said is kind of what I thought. Thanks!
    I am trying to find an answer kind of in relation to what you are saying about assembly code. I am working in Revit 2009, and it seems that the Assembly Code of an object has a correlation to what category controls it's lineweights. For example, I downloaded a curtain wall panel family, and couldn't figure out why the curtain wall family "glass" cut, lineweight wasn't adjusting what I had set to glass in the family. After further digging, I noticed that the family was set up assigned to a Window Assembly code. When I went back to the project and changed the Window "Glass" cut assignment, sure enough, that worked. What's really odd is that the family category is set to Curtain Panels...so, needless to say, this doesn't make much sense to me and wanted to see if someone could explain it.
    Thanks in advance!
    2007-09
    St. Louis, MO
    188
    Quote Originally Posted by josh.made4worship View Post
    Thanks in advance!
    I wish I could help you with that, but it sounds way above my head.
  1. Family Parameter Organization
    By james.klatt in forum Revit MEP - General
    Last Post: 2009-04-15, 04:10 PM
  2. Shared Parameter Organization
    By aaronrumple in forum Revit Architecture - Tips & Tricks
    Last Post: 2008-08-28, 11:24 PM
  3. Revit 2008 - Sheet Schedule Organization: Parameter / Filter
    By jkady in forum Revit - In Practice
    Last Post: 2008-06-09, 04:13 PM
  4. Family Drop-Down Organization
    By studio3p in forum Revit Architecture - General
    Last Post: 2004-06-03, 03:54 PM
  5. Family Organization
    By christo4robin in forum Revit Architecture - General
    Last Post: 2004-02-12, 12:48 AM
