Results 1 to 10 of 14
Thread: Blocks won't turn off
    2006-08
    Lake Charles, La.
    277
    Default Blocks won't turn off
    I have some blocks on a layer that is 'off', but the blocks won't turn off. Any ideas as to why?
    2004-08
    Hartford, Michigan
    3,192
    1 members found this post helpful.
    Default Re: Blocks won't turn off
    Quote Originally Posted by cwjean76 View Post
    the block doesnt appear to shut off because objects within the block are on different layers. If you wish for these blocks to "disappear" you must use freeze on the layer the block is inserted on.
    Christopher T. Cowgill, P.E.
    AEC Collection Civil 3D 2018
    Windows 10
    2006-08
    Lake Charles, La.
    277
    Quote Originally Posted by ccowgill View Post
    Thanks. That should've occurred to me. Feels like Monday rolled over into today.
    2006-12
    Big "D"
    3,711
    Just FYI, I always create my blocks on layer 0. When you do that, they block will take on the properties of whatever layer you put it on.
    Why is it called common sense when it is so rare?
    RevitForum.org
    2006-08
    Lake Charles, La.
    277
    Quote Originally Posted by dzatto View Post
    So do I and I thought everyone did. It just makes sense in my eyes. These were some drawings that I received and was cleaning up for our use. For some reason...that just didn't click with me, when I froze the layer, that that was the problem.
    2006-12
    Big "D"
    3,711
    Yeah, everyone "should" create blocks on layer 0. But we all know how that goes.........
    RevitForum.org
    2004-08
    Hartford, Michigan
    3,192
    that's the only reason I know why it wouldnt work. I wish I could convince everyone I work with to do it properly. At least when we redid our standards, I was the one in charge of modifying everything, it allowed me to fix our standard blocks so they were done properly.
    Windows 10
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    559
    I agree that block should be defined at layer 0. But are we forgetting here that xref's are also treated as blocks? In this case, we can't avoid there are other layers inside our xref. Just play with LAYFRZ's Nesting settings/options. (Block-level, Entity level and No nesting.) Somehow, you'll get what you need.
    Shielbern Bolalin
    Architectural 3D Renderer
    “A clever person solves a problem. A wise person avoids it.”
    1879-1955
    2006-12
    Big "D"
    3,711
    Quote Originally Posted by arshiel88 View Post
    They are? In what way? I thought Xref's were Xref's and blocks were blocks. Unless you bind an Xref, then yes, it is converted to a block and inserted in the drawing.
    RevitForum.org
    I could stop if I wanted to ameador's Avatar
    2006-02
    424
    I think what arshiel88 is saying is that xrefs act like blocks b/c they can be controlled by whatever layer to insert them on if it is not the "0" layer.
    Aka if you have "A-Anno-Note" layer set as current when you xref in a dwg (either overlay or attach) that xref will then "disappear" when A-Anno-Note layer is frozen.
    CAD user since '95, CAD Mgr since '07, BIM Lead, Mech Eng
    R10, R14, 2000i, 2002, 2004, ABS 2007, AMEP 2009, 2011, 2012, 2013, 2014, 2015
    RMEP 2011, 2012, 2013, 2014
    REVIT 2015, 2016
    Author of: http://ab-nerd-disc.blogspot.com/
  1. Turn Off Highlighting of Blocks
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2010-03-15, 01:21 PM
  2. is there a way to turn xrefs into blocks?
    By timsea81 in forum AMEP General
    Last Post: 2009-06-19, 01:02 PM
  3. blocks do not turn off when scale changed
    By piper in forum AutoCAD Annotation
    Last Post: 2007-09-25, 06:06 PM
  4. Base points in Blocks not behaving when I make Blocks use annotative scale
    By dood in forum AutoCAD Land Desktop - General
    Last Post: 2007-06-10, 04:51 PM
  5. Replies: 3
    Last Post: 2006-09-12, 11:17 AM
