Thread: Command Line capture
    2003-10
    688
    Default Command Line capture
    Is there a way to capture the command line text as it scrolls through on an OPEN? I'd like to be able to grab all the text that's in the F2 window immediately after open and set it to some sort of text variable. Is this possible?
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Command Line capture
    Quote Originally Posted by Coolmo View Post
    The only way I can think of is to use the log file. Maybe use some combination of LOGFILEMODE, or LOGFILEON and LOGFILEOFF, then open the log file to read in the text.
    Just an idea.
    Tim Creary
    S&D
    DILLIGAF
    2007-07
    Jo'burg SA
    4,344
    Possibly using a set of reactors, e.g. vlr-command-reactor, or vlr-editor-reactor, or vlr-lisp-reactor, etc.
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,706
    naaaa.... if you can manage that I want the code
    . . . in the mean time use the logfile.
    : ) Happy Computing !
    kennet
    The essential thing is what you write in the post. . . .not the numbers of posts.
    Moderator BlackBox's Avatar
    2,391
    Thumbs up Re: Command Line capture
    I was browsing the results from a search here on the forums, and came accross this thread hoping to utilize something fruitful.
    Instead I find something funny as hell:
    If = 0 then
    End If
    Hmm... did Coolmo induldge in one or two before writing his code...? You decide.
    Thanks Coolmo, you made my Friday!
    "Potential has a shelf life." - Margaret Atwood
  1. Replies: 3
    Last Post: 2009-10-22, 10:19 PM
  2. Replies: 6
    Last Post: 2007-04-23, 01:40 AM
  3. Replies: 1
    Last Post: 2006-11-16, 02:09 PM
  4. Replies: 4
    Last Post: 2006-05-09, 08:57 PM
