Thread: slanted riser on monolithic stair
    2007-03
    Salt Lake City
    360
    Default slanted riser on monolithic stair
    I can't seem to get the riser to show slanted on a monolithic or concrete stair.
    Any ideas why this is?
    Just found this... http://forums.augi.com/showthread.ph...+slanted+riser
    I'm guessing that it can't create a slanted riser if there is not enough of a nosing to slant from?
    2007-06
    Atlanta, GA
    54
    Default Re: slanted riser on monolithic stair
    Yes, you must have a nosing length to have a slanted riser. In fact the nosing length is how you set the angle of your riser.
    In 2008 (I have not yet tried it in 2009) you must NOT have a nosing profile in order to have a slanted riser. I'm not an architect but it makes sense to me that you would not want a slanted riser as well as a nosing profile since that would create more of a chance for someone to trip while going up the stair.
  1. 2013: Precast stair with rounded nose and slanted riser
    By dfi in forum Revit Architecture - General
    Last Post: 2014-03-27, 08:46 PM
  2. slanted monolithic stair
    By harkeychad in forum Revit Architecture - General
    Last Post: 2011-04-21, 01:09 PM
  3. End monolithic stair with riser??
    By cbaze in forum Revit Architecture - General
    Last Post: 2009-09-08, 04:28 AM
  4. Stair width varies using Monolithic stair family
    By d_lee.162829 in forum Revit Architecture - General
    Last Post: 2008-08-01, 11:39 AM
  5. Stair cut line display in 3 riser stair
    By christo4robin in forum Revit Architecture - General
    Last Post: 2003-09-01, 08:53 PM
