Summary: Dimension break command to work when an underlying dimension is overlapped by an arrowhead, not just a dimension line.
Description: Dimension break command - Need to have the "dimension break" command break dimension, extension and leader lines at opposing dimension and leader ARROWHEADS instead of just at the dimension line itself.
How Used: This helps with clarity of small dimensions (1", 2", etc.)on Architectural/Structural plans. When you only have a small dimension and other dimensions crossing and ending at one of the extension lines or leaders crossing and pointing to one of the extension lines, you can't tell what extension line it is to unless you break the one extension line that the arrow crosses. This is more crucial now that annotative dimensioning is available.
Feature Affinity: Dimensions
Submitted By: Tony Commero on March 5, 2008
