Thread: DWF Viewer
    2004-07
    5
    Question DWF Viewer
    I have Auto Cad LT 2004. How can I create a file that DWF Viewer can open? Thanks, Mike
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,259
    Talking Re: DWF Viewer
    Quote Originally Posted by mikeo
    I don't have LT< but, I am sure it is the same as plotting in Autocad.
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
    2001-03
    13,499
    Default Re: DWF Viewer
    Hi
    Might want to take a look at DWF Printer from Autodesk, the following thread contains information on this Windows Printer -
    Trouble Plotting to dwf
    Have a good one, Mike
    I could stop if I wanted to acad's Avatar
    Roanoke, VA
    355
    You don't need a Dwf Printer with LT 2004. You can use the PUBLISH command to publish a set of drawings (don't even have to open each one). You can also just find the DWF6 eplot from your plotter list.
  1. pdf viewer
    By peter.sedlacek in forum AutoCAD General
    Last Post: 2012-02-06, 01:02 PM
  2. AOE Viewer
    By LUKE.LOTHROP in forum Software
    Last Post: 2008-10-29, 05:06 PM
  3. dwt viewer?
    By Maverick91 in forum Software
    Last Post: 2008-10-01, 08:15 PM
  4. Replies: 2
    Last Post: 2006-11-27, 03:43 PM
  5. .pan or .ivr viewer??
    By christo4robin in forum Revit - Rendering
    Last Post: 2004-08-07, 03:43 PM
