Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Incorrect Schema?
    2006-01
    4,516
    Default Incorrect Schema?
    Anyone ever see this?
    End User made a local copy, and had been working in it for a few minutes. Got this error message when trying to STC or Save Locally.
    Save As worked fine, during which we made another local copy. Then STC worked fine.
    But ive never seen that message before, can anyone offer some insight as to what it means?
    2007-06
    Atlanta, GA
    54
    Default Re: Incorrect Schema?
    Nope, have not seen this at all. I'll be checking this thread though to see what the answer is.
    2006-01
    4,516
    We have ONE users workstation that has now produced this error twice, both in different local models. Other users in local models of the same file have not had any issues (ive never seen the error before), and in both cases, completing a Save As and renaming the local file seemed to fix the issue.
    Anyone at all?
    2007-08
    322
    I got this yesterday. I let me stc but not the local.
    Was wondering what it was myself....
    Nick
    2006-01
    4,516
    I never got an answer here, and never filed an SR over it. It only happened that one day, and weve been having some bizarre server issues.
    Considering it was isolated to one workstation, with two models, on one day, and never occured again, im leaning towards doing nothing, lol...
    2007-09
    56
    We just got the same error in a file with 10 users working in it. We too had crazy server issues over the weekend, on top of which we got the error immediately after a newbie saved his local over the central. The user did a 'save-as', & we were able to make new locals to continue to work, but it was an abrupt error that ended up costing us 17 man-hours, & we would like to avoid it in the future!
    Has anyone seen any resolution on this issue?
    2006-01
    4,516
    Resolution to which issue? The "incorrect schema" warning, or newbies saving over the Central File?
    I never got an answer to my inquiry, but i still think it was something with the workstation that was at fault.
    The other issue, well... Metal rulers, and swift justice.
    2007-09
    56
    Hahaha the "incorrect schema" issue is the one of interest here......
    The other issue has been rectified; though our dungeon is getting a little full......
    2005-07
    3,250
    Someone in our firm reported the same issue (incorrect schema). They couldn't get rid of it and had to recreate a new central file and new locals. Then it went away. Sounds like it has something to do with the GBxml schema perhaps? I think it's worth an SR.
    2006-01
    4,516
    Ours was a local file when it occurred, and it didnt affect anyone other than the one user with the offending hardware.
    Dave, is it doing it to EVERYONE in that project for you?
  1. 2013: Comment représenter mon schéma électrique dans REVIT?
    By guillaume7684 in forum Revit MEP - Général
    Last Post: 2017-01-30, 07:24 PM
  2. GS24-2: Creating FDO Schema
    By Autodesk University in forum Geospatial
    Last Post: 2013-04-17, 04:44 AM
  3. Schéma de surfaces à partir des Pièces
    By Do.Payelleville in forum Revit Architecture - Général
    Last Post: 2012-02-08, 10:51 PM
  4. 2011: Schéma de principe
    By Valou in forum Revit Architecture - Général
    Last Post: 2010-08-27, 06:05 AM
  5. Ch symboles pour schema de principe chauffage
    By phcorsaut in forum Revit Architecture - Familles
    Last Post: 2008-10-24, 07:26 AM
