Thread: Layout Tab Names as Fields
    Member ron.hodkins's Avatar
    13
    Question Layout Tab Names as Fields
    Has anyone done any work with the value of the layout tab name as a field?
    I know of the Diesel Expression "$(getvar, ctab)", but we have two pieces of data in the tab name that I would like to go to two different fields.
    Specifically, we include the sheet number and the sheet name on the layout tab so that they are included in the sheet name of the DWF file. But, I would like to pull those pieces of information into two different fields
    2004-11
    Altoona,PA
    299
    Default Re: Layout Tab Names as Fields
    See attached image:
    After I insert the titleblock into my Paperspace tab, the string of code reads the:
    Drawing NAME , Layout Tab NAME , TIME/DATE when plotting.
    Terry
  1. 2011: Publishing without layout names
    By Chuckyd67 in forum ACA General
    Last Post: 2011-09-29, 08:39 PM
  2. Publish layout tabs and layout tab names to PDF
    By dfuehrer in forum AutoCAD Plotting
    Last Post: 2005-11-09, 01:49 PM
  3. Fields Associated to Room Names & #'s
    By paltd in forum AutoCAD Fields
    Last Post: 2005-11-01, 10:39 PM
