Thread: 1200x600mm Ceiling grid
    2008-06
    Adelaide, South Australia
    279
    Default 1200x600mm Ceiling grid
    I know I must be missing something really obvious but I can't figure out how to change the ceiling grid from anything other than 600x600. Most projects we work on use a 1200x600 ceiling grid so it would be great if we could get this.
    What am I missing?
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Default Re: 1200x600mm Ceiling grid
    Select your ceiling, go to Properties > Edit /New > Duplicate (to create a new one with the new grid spacing) > Edit the ceiling structure > Select the finish material for the ceiling > Duplicate it > go to Surface pattern > New > Set the line spacing 1 to be 1200 and Line spacing 2 to be 600.
    I hope it helps.
    Andre Carvalho
    2008-06
    279
    Finally figured out what you meant by material. Didn't realize that material meant material in the drafting sense. Thought it meant in the physical sense.
    Seems to work now, cheers!
  1. Ceiling (Grid Only?)
    By cek in forum Revit Architecture - General
    Last Post: 2010-06-14, 07:06 PM
  2. Ceiling Grid
    By STHRevit in forum Revit Architecture - General
    Last Post: 2008-09-04, 07:35 AM
  3. Matching ceiling grid to ceiling rendering
    By Nevine in forum Revit - Rendering
    Last Post: 2004-11-27, 05:55 AM
  4. Matching ceiling grid to ceiling rendering
    By Nevine in forum Revit Architecture - General
