Thread: pasted items not plotting
    2004-08
    14
    Default pasted items not plotting
    when we special paste all our excel sheets on paper space, it will not plot
    if we special paste in model space and then vport it then it plots, any ideas why it will not plot when on paper space.
    2001-03
    13,499
    Default Re: pasted items not plotting
    Hi
    Haven't currently got access to AutoCAD (am at home) so can't experiment, will when I get to work tomorrow if you haven't received an answer by then; in the meantime have a look at -
    ID: TS21203 - Control visibility of OLE objects
    In the Plot Dialog Box -> Layout Settings tab -> Is Plot Paperspace Last check box ticked
    Could you post an example drawing file + excel file (if needed).
    What version of AutoCAD are you using?
    Have a good one, Mike
    2001-03
    13,499
    Hi
    Check out the following thread -
    Plotting OLE Objects
    If you're still experiencing problems could you please post a drawing file + excel file (if needed).
    2004-08
    14
    thanks, the plotter didn't like when i said the ole was line art but when i said it was text it plotted fine
  1. Replies: 3
    Last Post: 2011-11-22, 07:21 PM
  2. paperspace not plotting some items
    By rmclemore in forum AutoCAD General
    Last Post: 2010-09-01, 03:09 PM
  3. table loses formating when pasted
    By dcanfield in forum AutoCAD Tables
    Last Post: 2009-04-13, 08:41 PM
  4. Testing pasted format from .lsp
    By keelay711 in forum New Forum Users (Non technical)
    Last Post: 2007-02-16, 06:16 AM
