Thread: polyline edit - multiple
    2008-03
    5
    Default polyline edit - multiple
    Am I imaging this? After joining 2D polyline segments, the polylines remain on their original layer, but all of the vertices change to the current layer. If you pick the joined polyline to turn that layer off, you are notified that the layer is current and asked do you really want to turn it off? The fix is easy enough, but why should we have to bother? I am using AutoCAD Civil 3D 2008.
    Thanks in advance!
    stuwenk
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: polyline edit - multiple
    Quote Originally Posted by stuwenk View Post
    Thanks in advance!
    stuwenk
    Same here in Vanilla for heavy polylines. Odd. I could see this really messing with someone trying to purge unused layers.
    You work with PLINETYPE set to 0? Apparently you are creating or working with heavy polylines instead of lwpolylines.
    Tim Creary
    S&D
    DILLIGAF
  1. Macro for polyline edit
    By Michael J in forum AutoLISP
    Last Post: 2015-01-09, 06:18 AM
  2. Edit polyline by bearing
    By BILLYJOW in forum AutoCAD General
    Last Post: 2012-11-12, 04:20 PM
  3. Polyline Edit - Add multiple vertexes
    By roundbox52 in forum ACA Wish List
    Last Post: 2011-03-01, 11:57 PM
  4. 3d polyline elevation edit
    By jetaguy in forum Land Desktop - General
    Last Post: 2009-08-10, 01:38 PM
  5. Polyline Edit
    By birdcube in forum AutoCAD Civil 3D - General
    Last Post: 2008-10-02, 03:16 PM
