Thread: Rail Problem
    2006-09
    16
    Default Rail Problem
    I have attached a screen shot of floor plan of a stair. The rail on the bottom of the image is displaying on the wrong side of the cut line. Does anyone know what might cause this behavior and how to correct it?
    Brett
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Default Re: Rail Problem
    Make sure your railing is being hosted by the stair. Select the left railing > Edit > Set host > pick the stair.
    Andre Carvalho
    2006-09
    16
    The rail is hosted by the stair. I have sent the file to Autodesk Support. I'll let you know what they say. Thanks for the help.
    Brett
    2006-09
    16
    For anyone following this thread, the direction the rail was drawn makes a difference. The following is from Autodesk support:
    The underlying issue is being addressed by our development team on a future release. IT is being caused by the fact that the railing was drawn from the top down. There are two workarounds.
    - make cutplane of the view lower - 2' worked for the example in SPR folder (plan region around stairs will works as well if lower cutplane is bad for other elements)
    - recreate railings sketch starting from the bottom end.
  1. Sq Baluster - Rd Rail
    By jrostar in forum Revit Architecture - Families
    Last Post: 2010-10-06, 03:05 PM
  2. Stair rail help!!
    By Prusso in forum Revit Architecture - General
    Last Post: 2009-09-28, 08:10 PM
  3. Cut Rail?
    By Brandon_Pike in forum Revit Architecture - General
    Last Post: 2008-12-16, 01:38 PM
