Does anyone know how to turn off visibility of walls from lower floors? (I am seeing the walls drawn on the floor below and I have to go through and hide each one - there must be an easier way)
Have you put a Floor in yet?
the Walls below will show through if there is no Floor to hide them.
The other thing to look at is to make sure that the Walls below do not extend above your current Level
Also, check to make sure View Range is set to Associated Level. If it is set to a level below or Unlimited this can happen. If there is an area where you need to tweak View Range, do it with a Plan Region, rather than for the whole view, and you will save some time.
best,
Gordon
make sure you dont have an "Underlay" turned on
