Results 1 to 10 of 15
Thread: large topo files and computer hardware
    Active Member jbeaman's Avatar
    2003-02
    65
    Default large topo files and computer hardware
    I have a question about computer requirements, recommendations for using Land Desktop to work on very large topo files. What is going to make more of a difference? Processor speed or RAM or both?
    John
    Cairo - no, not Illinois
    5,069
    Default Re: large topo files and computer hardware
    RAM up to 2 Gb, maybe 3Gb if you boot with the appropriate switch, after that CPU and disk speed. Remembering that LDT has not been properly updated for 5 or 6 years now..... so handling large data sets is not efficient with lots of disk/file IO. It was written as an R12-DOS add-on after all
    2003-02
    65
    So will moving to a 64 bit OS with more RAM help when using LDT?
    2003-02
    65
    5,069
    Probably not. Actually that's almost certainly not.
    2003-02
    65
    That's interesting. Is there a reason why this is true?
    2003-02
    65
    Also, I'm working on a certain topo file that is taking up to 10 minutes just to quick save. I've purged everything that can be removed from the file out of it and it is still horribly slow to open, save etc. Would more processing speed help this or is this more than likely an issue with the file?
    2008-03
    Laurel, MD
    509
    Quote Originally Posted by jbeaman View Post
    What's your network speed? Or is this file local write?
    If it's located on your network and your running less than 1GB network connections with a somewhat modern desktop that can be your bottleneck. No amount of desktop upgrade will help beyond a certain point.
    2003-02
    65
    Good point. I'm gonna save it locally and try it again to see if that helps. I'll get back to ya after lunch
    2003-02
    65
    Nope, that's not the problem
  1. CM204-1: Getting the Most Out of Your Computer Purchase: Hardware Myths Revealed!
    By Autodesk University in forum CAD Management and IT
    Last Post: 2014-11-17, 05:42 AM
  2. Rendering issue - Suggested Computer Hardware Upgrades?
    By J3F in forum NavisWorks - General
    Last Post: 2009-04-07, 05:32 PM
  3. Replies: 6
    Last Post: 2007-06-08, 01:45 AM
