Thread: Bind a vault xref
    2008-03
    Laurel, MD
    509
    Default Bind a vault xref
    I tried search and found nothing.
    Here's the issue:
    I can not bind an xref that is attached from vault. An e-transmit doesn't do it. I can not do it inside the file.
    Anyone have a suggestion?
    2007-06
    271
    Default Re: Bind a vault xref
    What program are you using? If it's Civil 3D, and you're trying to bind an x-ref with grading objects in it, it won't work. That's the only thing I've found that won't bind.
    2008-03
    Laurel, MD
    509
    It is Civil 3d 2008. Sorry. I forgot to mention that. I suspected as much but was just looking for a second opinion.
    Member Keefe_Lee_G-and-O's Avatar
    2008-03
    Maryland
    49
    did we ever find an answer for this one??
    Keefe Q. Lee, C.D.
    Site Planner III
    Greenhorne & O'Mara Inc.
    Consulting Engineers
    Laurel, Maryland 20707
    www.g-and-o.com
  1. Bind xref and save as
    By Christopher_L in forum AutoCAD Customization
    Last Post: 2011-11-09, 11:22 AM
  2. Bind Xref's in C#
    By joelkarr in forum Dot Net API
    Last Post: 2009-01-29, 08:46 PM
  3. Bind xref
    By slaforest in forum AutoLISP
    Last Post: 2007-09-28, 01:31 PM
  4. Unable to Bind Xref's / Some Xref's no longer there
    By cwjean76 in forum AutoCAD General
    Last Post: 2006-12-22, 04:00 PM
  5. Xref Bind
    By rflores.73491 in forum AutoCAD General
    Last Post: 2005-01-05, 11:11 PM
