Results 1 to 7 of 7
Thread: Recurring Warning Dialogs
    100 Club jsr13's Avatar
    Virginia - USA
    130
    Exclamation Recurring Warning Dialogs
    Everything is running fine for our installation of ADT2004, but because many of our clients still use ACAD 2000/2002 we have the default set to save all of our drawings back to the 2k format for now. Makes sense, right? Well, every time we save a drawing we get the following the warning dialog box that says "Saving AEC objects to a previous version is not supported. Yada, yada, yada."
    We also get a similar warning when opening drawings from clients & our older stuff: "This drawing was last saved by an earlier version of this application. Saving the drawing will upgrade it to the current version which is incompatible with earlier versions."
    Here are the actual dialogs (if you're interested): AEC Objects and Incompatible Version
    Ok - I get it already! The problem is that they show up EVERY time we save/open these drawings. I would have thought that Autodesk would have some type of toggle for these (similar to the proxy graphics settings/options) that you can set so you don't see these warnings, but I can't find it or figure it out.
    Does anybody have a solution or know where one is? I know I can't be the only one out there that is having this problem.
    Thanks in advance!
    Jeff Rayhorn
    Sinclair Pratt Cameron, P.C.
    Consulting Structural Engineers
    Virginia Beach
    Virginia, USA
    2001-10
    Arizona
    2,337
    Default Re: Recurring Warning Dialogs
    I haven't tried this yet so it might not work.
    How about setting the EXPERT variable such
    that it suppress those messages in you
    template file.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    Virginia - USA
    130
    That was one of the things I tried first - but had no luck. I tried them all from 0 to 5 & still got the dialogs every time.
    Good thought, though.
    Any other ideas?
    Jeff Rayhorn
    Virginia Beach
    Virginia, USA
    Virginia - USA
    130
    Talking Re: Recurring Warning Dialogs
    OK - we got the answer (or it appears to be, anyway) from another outside source:
    AECFILESAVEMESSAGE
    This will not work until after you receive one of the dialog boxes in question (for some reason it gives you "unknown command"), but as soon as you get the dialog box, type it in at the command line. You'll receive this prompt:
    Display courtesy message when saving to a previous version file [Yes/No] <Yes>:
    Type NO and you'll not see them again.
    Thanks to all that looked for an answer, even if you didn't post.
    Jeff Rayhorn
    Virginia Beach
    Virginia, USA
    Administrator richard.binning's Avatar
    2001-05
    In the foothills of the appalachians
    2,258
    Quote Originally Posted by jsr13
    AECFILESAVEMESSAGE
    You'll also want to set "AECFILEOPENMESSAGE" to eliminate the message on file open.
    RLB
    Virginia - USA
    130
    ! ! ! ! ! Thanks!
    Why do they make it so hard to get along?? A simple toggle like the proxy graphics dialog......
    Ah, well.... That's why we do this, right?
    Thanks again.
    Jeff Rayhorn
    Virginia Beach
    Virginia, USA
    2002-07
    34
    A toggle has been added to ADT 2005.
    Thanks -
    chris yanchar | product designer
    building solutions division | autodesk, inc.
  1. Suppressing print warning dialogs
    By msiebert in forum Revit - API
    Last Post: 2012-12-24, 05:09 PM
  2. File dialogs
    By raymeek in forum VBA/COM Interop
    Last Post: 2008-03-17, 05:30 PM
  3. Getting started with DCL dialogs
    By Terry Cadd in forum AutoLISP
    Last Post: 2006-10-07, 02:13 PM
