Thread: FAO Symbol
    2003-09
    78
    Arrow FAO Symbol
    Morning all -
    I can't recall - does basic AutoCAD have a notation symbol for FAO (Finish All Over)? It's the little check mark that would have a numerical entry right above the left-most "leg". If not, I can't seem to figure out how to superscript either - short of a shape file.
    Thank you,
    Albert
    Albert Terrazas
    Wright Process Systems
    88 Commerce St
    Lodi, CA 95240
    (209) 369 - 2795
    (209) 369 - 8348 fax
    2001-03
    13,499
    Default Re: FAO Symbol
    Hi
    Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
    ID: TS51361 - Create subscript or superscript characters in multiline text objects
    ID: TS19200 - Create stacked multiline text
    ID: TS43338 - Creating text with superscript characters
    Have a good one, Mike
  1. symbol like the level symbol
    By Arkman in forum Revit Architecture - Families
    Last Post: 2010-05-06, 01:23 PM
  2. How do you add an elevation symbol to a symbol legend?
    By ron.wilkes in forum Revit Architecture - General
    Last Post: 2008-11-12, 03:43 AM
  3. Weld Symbol - Bottom Contour Symbol
    By kcooper.190440 in forum Revit Structure - Families
    Last Post: 2008-10-07, 07:21 PM
  4. End of Beam symbol - Not a Moment symbol
    By scowsert in forum Revit Structure - General
    Last Post: 2007-07-20, 04:09 PM
  5. 2006 LDT Symbol Manager importing existing symbol sets
    By hlecates in forum Land Desktop - General
    Last Post: 2006-02-06, 01:49 PM
