Thread: REMOVING Design Options
    2007-11
    50
    Default REMOVING Design Options
    I have a project where I modeled two options for a stair. The client has now decided on which option to move forward with, so now I would like to remove the design options from the model. Is it possible to completely get rid of the option sets and return model elements from an option set to the main model? THANKS in advance for any suggestions!
    Revit 2008
    2006-03
    London, UK
    810
    Default Re: REMOVING Design Options
    Check your help file, this is a direct quote:
    To incorporate a design option into the main model
    Click Tools menuDesign OptionsDesign Options, or click on the Design Options toolbar.
    In the Design Options dialog, select the design option set that includes the desired option.
    If the desired option is secondary, select the design option in the list, and click Make Primary to promote it to the primary option.
    Under Option Set, click Accept Primary to incorporate the primary option into the main model.
    Revit Architecture prompts you to confirm this action.
    Click Yes.
    Revit Architecture incorporates the primary option into the main model and deletes the design option set.
    Click Close.
    2001-12
    1,713
    Quote Originally Posted by raredmon View Post
    Revit 2008
    Set the one you want to keep as Primary, then Accept Primary, all withing the Design options dialog. This will move the Primary Option for that Option Set into the Main model, and delete all secondary options.
    best,
    Gordon
    Pittsburgh, PA USA
    1,906
    Revit 2008
    Set the Design option you want to be the Primary. Then select the Otion Set, and hit the button labeled "Accept Primary" This will remove that Option, Set, and move its components back into the Main Model.
  1. DESIGN OPTIONS
    By Tea_Berries in forum Revit Architecture - General
    Last Post: 2010-03-27, 07:07 PM
  2. Design process: Design options and Worksets.
    By Gordon.Price in forum Revit Architecture - General
    Last Post: 2007-09-11, 08:44 PM
  3. Removing Items from a Design Option
    By pashley in forum Revit Architecture - General
    Last Post: 2005-03-28, 11:57 PM
