Thread: Rebar Shape codes
    2007-12
    2
    Default Rebar Shape codes
    Hi there
    How do i change the rebar shape codes?
    I can put reinforcing into the columns, beams, spread footings etc. and schedule this but it is not the shape code that i want. I have the South African Standard shape codes file but how do i tell revit to use these codes?
    Another thing, How do you do the Reinforcing in slabs and schedule them?
    Thanks Ian
    2007-02
    92
    Default Re: Rebar Shape codes
    Hi Ian,
    You can simply draw your shapecodes by using the 2d rebar family template. File/New/Family. Pick the 2d Rebar shape template. Draw your shape and assign A,B,C etc parameters to it. Save it as the shapecode. Then load them all into your template.
  1. Rebar shape missing dimensions
    By szparaiso in forum Revit Structure - General
    Last Post: 2013-12-09, 03:17 PM
  2. 2013: how to create unattended 3d reinforcement bar shape (codes)
    By opesch in forum AutoCAD Structural Detailing
    Last Post: 2013-02-21, 07:26 PM
  3. rebar shape and legend
    By jbenoit44 in forum Revit Structure - General
    Last Post: 2010-11-26, 05:27 AM
  4. Rebar shape
    By annie123 in forum Revit Structure - General
    Last Post: 2010-02-22, 12:51 PM
  5. REVIT structure Can't solve Rebar Shape
    By agustnj.187972 in forum Revit Structure - General
    Last Post: 2008-08-11, 12:03 PM
