Thread: Reference drawing - attribute extraction without opening the drawing
    Member dkennard's Avatar
    2007-06
    Perth WA
    34
    Lightbulb Reference drawing - attribute extraction without opening the drawing
    Ok here's the silly question of the day.
    Is there a way to extract attribute data from a drawing without opening the drawing first?
    I was updating a bunch of reference drawing tables on a project this morning and thought it would be great if I could just select the drawing file (we always use part of the file name as the drawing number) and then extract the title attribute data from the drawing.
    I know I can do this by opening the or inserting the reference drawing but it would be much slicker if I did not have to "open" the reference drawing to get at the title data.
    I'm open to suggestions, or just plain old "thats the stoopidist idea ever"
    Thanks
    Dave.
    Houston
    7,519
    Default Re: Reference drawing - attribute extraction without opening the drawing
    Quote Originally Posted by dkennard View Post
    Sure, just use the ._EATTEXT (2002-2007 versions) or the ._DATAEXTRACTION command (2008 and later)
    2007-06
    Perth WA
    34
    Thnaks RK, I will give this a shot today.
    Dave.
  1. drawing extraction
    By lee.johnson in forum AutoLISP
    Last Post: 2012-05-20, 02:09 PM
  2. I want to create a drawing without opening a drawing.
    By mikeosborne in forum VBA/COM Interop
    Last Post: 2009-10-01, 06:12 PM
  3. Opening a drawing has changed
    By engineering.28250 in forum AutoCAD Map 3D - General
    Last Post: 2006-09-19, 05:29 PM
  4. opening a new drawing
    By zfoland20 in forum AutoCAD General
    Last Post: 2004-07-28, 08:26 PM
