Thread: Anyone use Autosketch? (V9)
    2
    Question Anyone use Autosketch? (V9)
    I'm looking for some help with fills and layers and stuff like that - anyone?
    2
    Default Re: Anyone use Autosketch? (V9)
    Quote Originally Posted by mjfarrell
    Best I can offer without a few more details
    Thanks, but I've tried the knowledge base and put a few questions on their newsgroup forum: this is sort of a last resort before I hunt down an e-mail address to give autodesk greif.
    Three layers - Fills, Drawing, Sizes.
    Sizes layer is hidden and locked, Fills layer is active, Drawing layer is unlocked and visible.
    Fill an area of the drawing with a bitmap fill.
    This fill is on top of the other layers and hides them:
    - move the fill object to the "drawing" layer and send it to the back - no problem; lines now show over the top of the fill.
    - make the dimension layer visible - the lines & text are hidden behind the fill.
    - move the fill object to the "dimensions" layer and send it to the back - text now shows (after refresh), but the fill hides the lines on the "drawing" layer.
    The layers were created in the above order, and I have tried re-naming them so that the "Fills" layer is at the top and bottom of the stack... no use.
    Can you help?
    2001-03
    13,499
    Hi
    Please note I've *moved* this thread from the AutoCAD General Forum to this one as I feel this particular Forum is a more appropriate place for such a topic (as this is not an AutoCAD issue / problem).
    Thanks, Mike
    Forum Moderator
  1. Fehlermeldung Autosketch CommCntrController
    By torben.bernhardt in forum Deutsch - AutoCAD LT / AutoSketch
    Last Post: 2008-12-08, 11:54 AM
  2. Autosketch v8 problem
    By mr_dfens in forum AutoCAD General
    Last Post: 2008-02-14, 12:46 PM
  3. InterOp libraries for Autosketch R7 and above
    By dean.richardson in forum Dot Net API
    Last Post: 2007-07-18, 04:01 PM
  4. AutoSketch - Open a SKD file
    By ajtrahan in forum Software
    Last Post: 2005-12-06, 03:21 PM
  5. AutoSketch
    By fletch97 in forum Software
    Last Post: 2005-08-25, 01:58 AM
