Is this possible in Revit? Do I have to build a custom arrow family? Is that even possible?
You can have multiple leaders from a single text object if that is what you are after.
Place a text note. Once placed you can select it and the option bar will change to allow placing of additional leaders, either left or right. If you select the remove leader option it will remove the leaders in the reverse order they were placed.
____________________________
Dimitri Harvalias LEED AP
Summit BIM Consulting
BIMblog.ca
I was never just a CAD monkey, so I refuse to be a BIMpanzee!
A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
Nodes. I only see one node in Revit. I need several (multi-node). See pic below.
I do not need multiple arrows coming from one text box/annotation; just the ability to do this as shown below.
Ahhhh. I see now.
Straight, arc or one elbow is all you get out of the box.
You could probably create a generic annotation of some sort that might satisfy your needs.
BIMblog.ca
This was a long-standing wish of mine as well. Sometimes it's really obnoxious, but for the most part, this really falls into the category of 'graphic conventions' - and generally there's no use fighting Revit on that front.
http://forums.augi.com/showthread.php?t=30961
The link to the spline leader thread was great, thanks very much.
Now, how do I create spline leaders? Not aware that it is an out-of-the-box option.
