I'm using Autocad raster design 2007 and I'm trying to convert Vector line and text to Raster. The Line work is converting However my Arial text is not and I'm being told that...... None of the vector entities selected are currently supported... However when I use*.shx type fonts the text will convert. In older versions of the software this did not matter. Is there a solution to this. It even won't convert blocks contaning TTF fonts. That is the fonts in the block the lines convet.
Help
