Results 1 to 10 of 12
Thread: Lisp to extract Handle
    2008-03
    7
    Default Lisp to extract Handle
    How can i write a lisp to extract the handle of an object and then paste it in the dwg?
    0,0,0 The Origin
    8,569
    Default Re: Lisp to extract Handle
    You'll probably get better help from the lisp forum.
    John B
    2015-11
    Jo'burg SA
    4,512
    Here:
    (defun c:ShowHandle (/ en ed newtxt)
      (if (setq en (entsel "Pick object: ")) ;Ask user to select object
        (progn
          (setq ed (entget (car en)))    ;Get data of object
          ;; Create new text object's data
          (setq newtxt (list '(0 . "TEXT")
                 (assoc 10 ed)    ;Insert point on the same os the object's 1st point
                 (cons 1 (cdr (assoc 5 ed)))
                        ;Text value as per object's handle
                 (cons 40 (getvar "TEXTSIZE"))
                        ;Text height as per default
               ) ;_ end of list
          ) ;_ end of setq
          (if (setq newtxt (entmake newtxt)) ;Create the text
        (alert
          (strcat
            "The object's handle ["
            (cdr (assoc 5 ed))
            "] is now copied to a text object.\nUse last to select it."
          ) ;_ end of strcat
        ) ;_ end of alert
        (alert
          (strcat
            "There was an error creating the text.\nHowever, the entity's handle is:\n\n"
            (cdr (assoc 5 ed))
          ) ;_ end of strcat
        ) ;_ end of alert
          ) ;_ end of if
        ) ;_ end of progn
        (princ "Canceled")
      ) ;_ end of if
      (princ)
    ) ;_ end of defun
    2008-05
    3
    Would it be possible to modify the Lisp to pick several objects and show the handle instead of 1 at a time?
    Thanks
    2004-08
    Hartford, Michigan
    3,192
    Quote Originally Posted by dmccann.183909 View Post
    Thanks
    how would you know which handle belongs to which object?
    Christopher T. Cowgill, P.E.
    AEC Collection Civil 3D 2018
    Windows 10
    2008-05
    3
    The lisp already places the text at the objects base point, why couldn't it cycle through each object to do the same thing. A program that I use to place location points on my drawing for hangers does this so it must be possible.
    2004-08
    Hartford, Michigan
    3,192
    Sorry, I didnt actually read the lisp routine. After looking at it, you could use the ssget function, with a while loop to cycle through each selected object.
    Windows 10
    2001-12
    St. Louis
    5,191
    Quote Originally Posted by jaberwok View Post
    I've moved this thread from the General forum to the lisp forum.
    Cheers.
    (missing MEP/FP and Revit)
    2015-11
    Jo'burg SA
    4,512
    Quote Originally Posted by Ducky View Post
    Thanks
    Something like this:
    (defun c:PlaceHandles (/ ss n ed sz)
      (setq sz (getvar 'TextSize))
      (prompt "Select objects: ")
      (if (and (setq ss (ssget)) (setq n (sslength ss)))
        (while (>= (setq n (1- n)) 0)
          (setq ed (entget (ssname ss n)))
          (entmake (list '(0 . "TEXT")
                         (assoc 10 ed)
                         (cons 40 sz)
      (princ)
    Much reduced and not tested much, but should do a lot similar to my earlier code - only that alert is omitted since i don't think you want a dialog popping up for each entity selected.
    Note this is a really basic code. The text would always be placed on Layer 0, and no accommodation for annotative or any such, also the MS / PS tab is disregarded. I still can't really figure what use a handle is for the normal acad user though, but it's possible to show of course.
    2015-11
    Jo'burg SA
    4,512
    Excuse me if this sounds "harsh" ... but what do you actually want with the handle? To me it seems rather useless to have a hexadecimal number displayed for each object. It doesn't read well for a human, its only use is to uniquely identify each object in the drawing - and in most cases only for a program. Thus I can much more easily see uses for a defun returning a list of handles, than for one creating text of displaying these handles in a dialog / text screen.
    Now if you want it the other way round: Say you've got a txt file exported through AttOut and you want to find the block reference with a handle "ABC". Then look for the built-in lisp function handent.
  1. Extract the radius of a 3D cylinder using LISP?
    By Cadapult in forum AutoLISP
    Last Post: 2013-06-06, 08:30 AM
  2. Lisp for Handle
    By tguy in forum AutoLISP
    Last Post: 2008-07-11, 02:08 AM
  3. Create lisp to extract data from excel file
    By Lions60 in forum AutoLISP
    Last Post: 2008-01-30, 04:32 AM
  4. Replies: 5
    Last Post: 2007-04-30, 08:14 PM
  5. Lisp to extract and add numbers from text/mtext string
    By cblendermann.91943 in forum AutoLISP
    Last Post: 2005-08-18, 03:25 PM
