mjfarrell
Go to surface display Slope Banding 2d solids
and have it do say 7 slope ranges.
I suspect that you will find vertical faces in your
model are the cause of the problem.
That or re-run the data with a much smaller grid size and
see if they do not come into closer agreement with each
other.
Or set the volume surface current and generate contours and look to see if they make sense
NOTE the contoures will be 'relative' not actual elevations.
So a 1 foot fill will be the 1' contour line......
