Thread: Support File Search Path in LT
    2008-05
    41
    Default Support File Search Path in LT
    We have created company cad standards and all the LT users need to be directed to the appropriate folders and files. So every user needs to be logged on and I need to set their settings in ->Tools, ->Options etc. etc.
    My question is . . .
    Is there a quicker way of doing this?
    Where does Autocad store these settings?
    J
    Earth
    9,804
    Default Re: Support File Search Path in LT
    AFAIK - it's just like AutoCAD and it's stored in the HKCU tree of the registry. With AutoCAD, you can use a startup lisp to set these settings inside AutoCAD.
    With LT, I suppose you could use an O/S startup file (i.e.: logon batch file) to import a properly configured .REG file. I don't see why that wouldn't work.
    R.K. McSwain | CAD Panacea |
    2008-05
    41
    Thanks for your help, I will give it a try.
    J17
  1. Adding To Support File Search Path
    By aaronic_abacus in forum AutoLISP
    Last Post: 2012-03-19, 10:16 PM
  2. Support File Search Path
    By flenoir in forum Dot Net API
    Last Post: 2010-10-05, 09:25 AM
  3. add a directory to Support File Search Path
    By NerdlingOne in forum AutoLISP
    Last Post: 2010-01-11, 08:52 PM
  4. Support file search path
    By Kid-Zort in forum AutoCAD Customization
    Last Post: 2008-10-31, 08:43 PM
  5. Support file path search and sub-folders
    By johan d in forum AutoCAD General
    Last Post: 2006-07-05, 01:40 PM
