Results 1 to 8 of 8
Thread: Dashed and Dot to Hidden
    2007-02
    Porto
    107
    Default Dashed and Dot to Hidden
    Hi guys,
    Could someone tell me, if it's possible (with a lisp code) to change Dot and Dashed linetype to Hidden?
    Earth
    9,805
    Default Re: Dashed and Dot to Hidden
    Do you want to change the linetype of layers or of entities or of both?
    R.K. McSwain | CAD Panacea |
    2007-02
    Porto
    107
    Some drawings have layers with other linetypes and have objects too. I think the best solution would be to change the layers, or the objects, so that there would be just the sort of hidden linetype.
    2005-06
    in the upper right corner
    3,508
    Quote Originally Posted by pt_zooropa View Post
    Well here's a quick, crude stab at what a routine may look like.
    (defun c:hidlt ()
        (command "-layer" "ltype" "hidden" "test" "") ;; changes the linetype to hidden on "test" layer
        (command "_chprop" "all" "" "ltype" "bylayer" "") ;;changes all entites' linetype to ByLayer
    (princ)
    There's probably a better way, but it's a start.
    Good luck...
    Last edited by tedg; 2008-07-14 at 07:46 PM. Reason: Fixed CODE TAGS, accidently re posted (doh)
    2007-02
    Porto
    107
    Ok. I dont want to change entities to Bylayer, only change all entities of drawing to specific Layer and keep linetypes. Only Dot and Dashed must change to Hidden.
    Thanks.
    2007-08
    202
    Hi,
    Try this:
    (vl_load_com)
    (vlax-for blk (vla-get-Blocks
    		(vla-get-ActiveDocument (vlax-get-acad-object))
      (vlax-for obj	blk
        (if	(and (vlax-property-available-p obj 'LineType T)
    	     (member (vla-get-Linetype obj) '("DOT" "DASHED"))
          (vla-put-lineType obj "HIDDEN")
    2007-02
    Porto
    107
    Thanks for your help!
    But it returns error:
    "no function definition: VLAX-GET-ACAD-OBJECT; error: An
    error has occurred inside the *error* functionAutoCAD variable setting
    rejected: "blipmode" nil"
    2007-08
    202
    Sorry,
    You got this message because I forgot to add a (vl-load-com) at the begining.
    This expression is needed to load the vlax functions. You can add it to your startup suite so that the vlax functions should be automaticaly loaded.
    ; error: An
    This message means that the *error* function haven't be reset to the built in one in another routine which redefine it (restting blipmode sysvar).
  1. Hidden or dashed Linetype
    By Ehsan in forum 3ds Max - General
    Last Post: 2012-04-28, 05:33 AM
  2. Hidden dashed line not showing up in paperspace
    By Suzyq8284 in forum AutoCAD General
    Last Post: 2009-03-04, 08:46 PM
  3. Batt Insulation as a Hidden (Dashed) Linetype
    By raddis in forum Revit Architecture - General
    Last Post: 2006-08-17, 06:06 PM
  4. Dashed (Hidden) Lines in Family Editor
    By gordgraff in forum Revit Architecture - Families
    Last Post: 2005-04-22, 02:13 AM
  5. Hidden and Dashed Lines
    By stathamwoodwork66052 in forum ACA General
    Last Post: 2004-07-07, 02:35 AM
