Thread: Slab Edge and Multi-Layer Floors
    2001-07
    Phoenix, AZ
    959
    Default Slab Edge and Multi-Layer Floors
    The Floor I use for my slab-on-grade is muti-layered and shows the concrete slab and the gravel base beneath it (and occasionally the amount of compressed soil as required by our soils report).
    I want to use a Slab Edge to create a standard haunch along the edges. But when I use the OTB Profile for this the gravel base cuts through the Slab Edge. At first I thought it might have something to do with the layer function (structure, finish, substrate, etc.) but I've been testing different options and haven't found anything that works.
    I've attached images of what it looks like before and after you join the Floor and Floor Slab edge.
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Default Re: Slab Edge and Multi-Layer Floors
    I think that's a bug... We have discussed that already at http://forums.augi.com/showthread.php?t=80711
    Andre Carvalho
    2001-07
    Phoenix, AZ
    959
    Argh! Bummer... well at least I know it's not just me. Thanks.
  1. 2011: Multi-story exterior wall, trimming framing at slab edge
    By nrollins in forum Revit Architecture - General
    Last Post: 2011-08-15, 09:21 PM
  2. slab-on-grade with gravel and thickened slab edge joining
    By t1.shep in forum Revit Architecture - General
    Last Post: 2009-11-23, 03:04 PM
  3. Slab Edge Profile not loading under Floor-Slab Edge
    By John Anderson in forum Revit Architecture - General
    Last Post: 2008-06-16, 05:44 PM
  4. Floor Slab Edge on Warped Floors
    By chriscooper in forum Revit Architecture - General
    Last Post: 2007-04-26, 04:09 PM
  5. Floor Slab Edge host sweep type on a sloped slab
    By gravelin in forum Revit Architecture - General
    Last Post: 2005-02-17, 06:47 AM
