Hi,
Have you any idea how to model monolithic stairs like in the attached files?
Hi,
Can't.
Monolithic stairs only work on straight runs and landings, and spirals where each tread is identical.
You can get a close if you use a standard stair template, go to properties, make the tread depth equal to your riser height, eliminate the stringers and risers (or create a custom nosing profile equal to the riser height if you want a slanted riser).
If you want a smooth underside, try using a middle stringer only, and make it the width of your stairs. You'll have to add some in-place solids at the winder portion, as the stringer won't follow them.
