Thread: MSG: g3vacedl.arx cannot find a dll or other file it needs
    2007-03
    Default MSG: g3vacedl.arx cannot find a dll or other file it needs
    I got this message when I save file. How can I avoid this message?
    In addition, what should be done so that the numbers displayed in Command window have more than 2 decimal places?
    Thanks for reply.
    I could stop if I wanted to scott.sheppard's Avatar
    2005-07
    Scottsdale, Arizona
    226
    Default Re: MSG: g3vacedl.arx cannot find a dll or other file it needs
    1. That message means that your install is corrupt. You should re-install.
    2. If you wish to measure DWF files with more precision, you need to increase the vector DPI of AutoCAD. See http://autodesk.blogs.com/between_th...rge_of_a_.html for more info.
  1. amg3dim.arx cannot find a dll or other file that it needs.
    By Phil Gravel in forum AutoCAD Mechanical - General
    Last Post: 2012-09-20, 11:58 AM
  2. Cannot find the specified drawing file
    By ctc in forum DWG TrueView - General
    Last Post: 2010-05-12, 12:49 AM
  3. ARXLOAD1 can't find file
    By eleonard in forum AutoCAD Civil 3D - Land Desktop Companion - General
    Last Post: 2007-05-30, 09:10 PM
  4. Script file does not work on one PC - Can't find file
    By jskripac in forum AutoCAD LT - General
    Last Post: 2006-06-06, 07:38 PM
