Thread: Polar Stretch + Array
    2007-06
    5
    Cool Polar Stretch + Array
    Looks like I really have no luck lately with polar stretch - only this time it includes array as well. I need green line to be arrayed every 15 units and stretched which works fine until I try to stretch it on an angle... then it doesn't rotate arrayed green line (which should always be on 45d angle to line I am drawing). It is such a simple task and I can't figure out why it's not working - quite frustrating. Any help would be tremendeously appreciated
    2007-06
    5
    Angry Re: Polar Stretch + Array
    I got it working except that arrayed lines are following direction only when I click on grip twice on the same spot. Is that a dynamic block bug or is it me?
  1. 2011: Polar Stretch and Linear Stretch don't work together?
    By gino.timonin944148 in forum Dynamic Blocks - Technical
    Last Post: 2011-12-18, 06:49 PM
  2. Polar stretch or rotate with stretch help
    By Opie in forum Dynamic Blocks - Technical
    Last Post: 2008-08-15, 10:43 PM
  3. Polar Stretch w/ Attributes
    By amandas in forum Dynamic Blocks - Technical
    Last Post: 2008-08-13, 01:21 PM
  4. Polar stretch and Array not working properly with Dynamic Block
    By r424andy in forum Dynamic Blocks - Technical
    Last Post: 2006-12-20, 03:31 PM
