Results 1 to 6 of 6
Thread: Rendered Lighting On, but doesn't show up...
    2008-05
    Default Rendered Lighting On, but doesn't show up...
    I'm having trouble getting lights to be "on" in an interior rendered view. In the artificial lights dialogue box they are on and the dimmer is set to 1. However when i render the lights don't produce any light. The lights i want to render are basic recessed cans. Is there another setting that i need to change to make them turn on?
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,535
    Default Re: Rendered Lighting On, but doesn't show up...
    a couple things to try:
    First, is there daylighting in the scene as well? If so, and there is a fair amount of it sometimes that simply drowns out the (relatively) small amount of light coming from an artificial fixture. This is acurate to reality...
    Is this an upgraded project? Any lighting families from previous versions should be opened and saved in 2009 or the lighting won't work. It's a product of the change to the rendering engine and how lighting works. Try opening, saving, and reloading the family.
    Lastly, make sure there is no geometry in the family blocking the light.
    HTH
    AUGI Addict hand471037's Avatar
    2003-05
    Oakland, California
    1,934
    Quote Originally Posted by slimchaz View Post
    One last thing. If the lights are nested into a family (for example, you've got a family of four lighting can families nested together into a single light fixture family) that you've got to set them to be 'Shared' families in order for the lights to turn on.
    2008-05
    Brunei
    299
    Check "Rendering" tab.
    Then check the "Scheme" under "Lighting".
    Select the right "scheme" suited for you're scene.
    You can start with "Interior:Artificial only" if you dont have any outside light coming in into you're scene.
    All AUGI, all the time Firmso's Avatar
    2006-03
    Here, Still
    549
    Try doing a new Scene (Render>Settings>Name...) for your new lighting settup.
    2004-05
    792
    If you upgraded your file to 09 from 08 you will have to use 09 light fixtures the 08 's do not have the same capability,
  1. 2014: How to show Gridlines in rendered images
    By lys.pcube611532 in forum NavisWorks - General
    Last Post: 2014-10-29, 01:46 AM
  2. 2013: Interior Lighting - lights stay dark when rendered
    By silversurfer790 in forum Revit Architecture - General
    Last Post: 2013-10-04, 06:38 PM
  3. Show us your Rendered Images
    By navisworks in forum NavisWorks - General
    Last Post: 2009-03-27, 07:54 PM
  4. RPC Families don't show unless rendered
    By Rustle in forum Revit - Rendering
    Last Post: 2008-07-14, 07:05 PM
  5. Daylighting and Indirect Lighting in Rendered View
    By artitech in forum Revit - Rendering
    Last Post: 2005-10-25, 12:22 PM
