Thread: Specify New Work Plane - doesn't work?
    2008-07
    11
    Default Specify New Work Plane - doesn't work?
    I attached some beam systems to a work plane "x". I need to change them and have created a new work plane "y". When I click on my beam system, go to edit work plane, and try to specify new work plane - only ref planes "a", "b", "x" show up. I have about a dz. different ref planes in addition to "y". Can anyone tell me why they do not show up in the pull down menu and why I can't change my beam system from one ref plane to another?
    I've tried "disassociate" and am not getting anywhere with that either.
    I've already had to scrap and re-draw this all once. I thought there was a way to change this without having to start over every time a slope changes.
    Fyi - all my planes are named and I've tried actually rotating the ref plane line more than once, it doesn't work.
    2003-04
    Irvine, CA
    6,807
    Default Re: Specify New Work Plane - doesn't work?
    You can't reassign the workplane if the new plane is not parallel to the original. You can rotate a reference plane so you could move the reference plane to a "known point" of reference, then rotate it using that as your origin for rotation. If you can't do that for some reason like the reference has other things associated to it that shouldn't change then create a new Reference Plane that is parallel to the original, reassign the workplane and then rotate the new one.
  1. DYN doesn't work
    By geohutto520336 in forum AutoCAD LT - General
    Last Post: 2012-02-04, 07:28 PM
  2. Reference Plane as Work Plane
    By gdb in forum Revit Architecture - General
    Last Post: 2012-01-04, 02:09 PM
  3. ConvertPoly doesn't work?
    By cadtag in forum AutoCAD General
    Last Post: 2009-12-21, 08:29 PM
  4. YES or NO to all doesn't work???
    By csmac2004 in forum Productstream - General
    Last Post: 2009-03-03, 05:31 PM
  5. Aligning Work Planes to Model (was "Work Plane Visibility" in Wishlist)
    By funkman in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-07-16, 03:28 AM
