Thread: FILTER.dcl
    4
    Default FILTER.dcl
    I have recently upgraded from ACAD 2004 to ACAD 2005 with floating profiles over our NT server. Since the upgrade, I cannot use the FILTER command. I get an error message stating: "Can't locate dialog definition file filter.dcl. Check your support directory".
    Under options I have mapped to every folder under
    \application data\autodesk\autocad 2005
    as well as
    \local settings\application data\autodesk\autocad 2005.
    In addition, I've searched both the install disk and my cpu for Filter.dcl with zero results. I am assuming that the programming for this DCL is nested in one of the other program files. Does anybody know how to fix this issue and/or where the default location for filter.dcl is?
    Rey Flores
    Matrix Consulting Engineers
    2001-03
    13,499
    Default Re: FILTER.dcl
    Hi Rey
    Please note I've *moved* this thread from the AutoCAD General Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    2001-10
    Arizona
    2,337
    Here is a possible source for this problem:
    http://usa.autodesk.com/adsk/servlet...linkID=2475323
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2001-03
    13,499
    Quote Originally Posted by rflores.74287
    Hi
    Filter.dcl should be found in the "Support" directory/folder of the AutoCAD installation.
    Have you searched the "C" Drive for Filter.dcl (am assuming you installed AutoCAD on the "C" Drive).
    If no luck, try a Repair on the AutoCAD install, if still no luck you might be best just doing a complete uninstall / reinstall.
    Have a good one, Mike
  1. Filter
    By sandeep_koodal in forum AutoCAD Tips & Tricks
    Last Post: 2009-09-14, 09:46 PM
  2. Phase filter over rides messing with Filter over rides
    By tim.101799 in forum Revit Architecture - General
    Last Post: 2008-10-30, 08:20 PM
  3. FILTER
    By Maurice.148748 in forum AutoCAD General
    Last Post: 2007-10-09, 04:52 PM
  4. Filter!
    By tha in forum Revit Architecture - General
    Last Post: 2007-08-08, 07:18 PM
  5. filter
    By Cheuk Ling in forum Revit Architecture - General
    Last Post: 2007-01-15, 12:45 AM
