Thread: Railing Baluster Locations
    All AUGI, all the time DanielleAnderson's Avatar
    2004-06
    Mostly in Mom-land
    704
    Question Railing Baluster Locations
    I am creating a very specialized railing system for a residential deck (galvanized steel rods, steel balusters, etc) and I need to get the balusters to line up with the window mullions (to protect the amazing view). Is there a way to tell revit where I would like the balusters specifically? They don't end up being a uniform distance apart.
    Thanks!
    All AUGI, all the time christo4robin's Avatar
    2003-05
    Boulder, Colorado
    681
    Default Re: Railing Baluster Locations
    Danielle,
    In similar situations, I have used a generic family for the railing posts, then used a railing object for any continuous rail. In general I find that for a railing that is other than completely basic, I use a combination of 1 to 3 railing objects and a smattering of generic model components to get things just right.
    Cheers!
    2004-06
    Mostly in Mom-land
    704
    I was afraid that might be the answer...note to developers: placing balusters would be a fabulous feature to add...
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,348
    Try breaking the line segments in the railing sketch. At each break you'll get a baluster.
    2004-06
    Mostly in Mom-land
    704
    AHA! I knew there had to be some sort of solution.
    Thanks Wes.
  1. Railing -Baluster Cleanup
    By mme.peel28292390 in forum Revit Architecture - General
    Last Post: 2011-11-23, 07:53 PM
  2. Railing baluster problem
    By Carlos GT in forum Revit Architecture - General
    Last Post: 2007-12-13, 02:35 PM
  3. Railing, baluster problem.
    By space_spikes in forum Revit Architecture - General
    Last Post: 2007-11-21, 01:17 PM
  4. Railing and Baluster frustration!
    By Shaun v Rooyen in forum Revit Architecture - General
    Last Post: 2006-02-08, 04:59 PM
  5. Railing / Baluster question for stairs...
    By twiceroadsfool in forum Revit Architecture - General
    Last Post: 2006-01-10, 02:10 PM
