Thread: Some elements cannot change workset
    2003-07
    Roseville/Sacramento, CA
    53
    Default Some elements cannot change workset
    Why is is that there are a few rogue elements in a file that in the element properties dialog have the workset value grayed out? I have a door that is in a wall that is "future" workset but the door is in "new shell".
    What gives?
    I have some walls that behave the same way. For no apparent reason their workset cannot be changed thru the element properties dialog box.
    Has anyone had this problem before?
    2006-06
    Toronto, ON
    2,386
    Default Re: Some elements cannot change workset
    Make sure the workset of the element you want to change is set to be "Editable". Or, when you select the object, if it is not editable you will see a small "puzzle piece" icon close to it. Click there and the element will be editable. Now you can change the element's workset.
    Andre Carvalho
    2003-07
    53
    Well, that was easy enough. Thank you.
  1. Retain workset association when copying elements to another location.
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2015-12-14, 03:04 PM
  2. 2013: Can't remove elements from workset.
    By CelsoBRA in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2013-06-04, 12:53 PM
  3. Cannot borrow elements without taking entire workset
    By dfi in forum Revit Architecture - General
    Last Post: 2011-04-06, 06:53 AM
  4. Moving elements to another workset
    By wags5116 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2009-11-19, 10:23 PM
  5. [2010] Copy Elements Onto Similar Workset (OPEN)
    By mwiggins121466 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2009-07-10, 04:26 PM
