Thread: Plotting problem with Designjet 430
    2003-08
    3
    Default Plotting problem with Designjet 430
    We have a Designjet 430, with the original 4 MB memory, and use Autocad 2004 and Autocad LT2000, when I tried to print a file (size about 400 MB) on D size, I did not print complete and got an error message of DATA on the printer but the same drawing print well on Tabloid Size (11 x 17), I have also printed drawings with a larger file size (like 1.5 MB) with no problems. I wonder if it may be a problem with the Autocad File or with the printer, like not good communication or not enough memory. We also recently installed the Windows XP Service Pack 2, but the HP site is a mess and it was not possible to access information about drives, etc.
    Thank you for your help with any suggestion.
    2015-12
    Arizona
    2,478
    Default Re: Plotting problem with Designjet 430
    Can we isolate the cause of the probelm?
    Is the data over-run error resulting from 2004
    or from 2000LT?
    2003-08
    3
    Thank you, We had the problem with both AutoCad and AutoCadLT, maybe is the printer's memory, We checked this morning and we will expand it (it's cheaper nowadays), We hope it will solve the problem.
    13,656
    Hi
    Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
    ID: TS67474 - Plotter out of memory, or only partial drawing is plotted
    ID: TS15952 - Memory requirements for plotting drawings to Hewlett-Packard plotters
    ID: TS50644 - Print overrun error message on HP LaserJet printers
    Have a good one, Mike
    2003-08
    3
    Red face Re: Plotting problem with Designjet 430
    We bought a 32 MB memory expansion, at good price directly from Kingston, and now the problem is solved.
    Thank you to everybody who answer this posting.
  1. Replies: 1
    Last Post: 2006-10-10, 09:36 AM
  2. Plotting to HP DesignJet 600
    By mpoole in forum Revit - Hardware & Operating Systems
    Last Post: 2005-01-24, 07:33 AM
  3. Raster/vector Plotting - XP to HP Designjet 230
    By rreinwald in forum AutoCAD Plotting
    Last Post: 2004-12-31, 07:31 PM
  4. Plotting to HP DesignJet 600
    By mpoole in forum Revit - Plotting/Printing/Exporting
    Last Post: 2004-11-17, 10:35 PM
