Thread: Stair width varies using Monolithic stair family
    2008-03
    14
    Default Stair width varies using Monolithic stair family
    I have a stair that goes up 4'-0" and is monolithic. The problem I have is that the stair width changes from 4'-0" to 4'-6". The change occurs on the third 6th, 7th and 8th tread. Those treads need to be 4'-6" while the lower treads need to be 4'-0". Any help is appreciated. I've been trying to find someone who has run into the same problem, but maybe I'm using the wrong key words. Thanks.
    Dean
    2006-06
    Toronto, ON
    2,386
    Default Re: Stair width varies using Monolithic stair family
    Dean,
    When building your stair, use "Boundary" instead of "Run" to create the two boundaries with the shape you want. Then use "Riser" and start adding risers manually. It will do exactly what you want.
    Andre Carvalho
    2006-03
    London, UK
    810
    Or, alternatively, create the stair with Run, then Edit the stair sketch and edit the boundary line. To avoid the 'stairs must consist of two boundary lines" error, I use the Split tool to create new 'corners' in the boundary line, without interuppting its continuity.
  1. monolithic stair end
    By cr_gixxer in forum Revit Architecture - General
    Last Post: 2012-11-02, 01:27 PM
  2. 2013: Monolithic stair
    By rob.127056 in forum Revit Architecture - General
    Last Post: 2012-10-31, 12:02 AM
  3. Could you make a monolithic stair as a column family?
    By 3dway in forum Revit Architecture - Families
    Last Post: 2009-10-23, 01:09 PM
  4. Monolithic Stair
    By Jun Austria in forum Revit Architecture - General
    Last Post: 2009-01-17, 11:29 PM
  5. monolithic stair
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2005-03-21, 05:02 AM
