Results 1 to 10 of 16
Thread: Solid Black "Filled Region" Does Not Print
    2007-11
    50
    Default Solid Black "Filled Region" Does Not Print
    Why do annotation filled regions (solid black) not print at all? I have an annotation symbol for my exit signs that use an annotation solid black filled region - it looks good on screen, but the sold black DOES NOT PRINT! Please help if you have a suggestion!
    (P.S. - It is a nested family, the symbol is nested into the exit sign generic model to show up on plan)
    Revit Arch. 2008
    2005-11
    Minneapolis, MN
    14
    Default Re: Solid Black "Filled Region" Does Not Print
    Try printing with "Raster Processing" (instead of vector). This is an issue that the Revit team has been made aware of. I haven't checked if it has been fixed in 2009, but in 2008, this was a BUG.
    This is specific to solid filled regions used in nested annotations.
    2007-01
    455
    Try printing to PDF first. When you open the PDF file in acrobat, are the filled regions black?
    If so, try printing the PDF to paper. How does the solid black print from the PDF file?
    My point is, it's possible there is something else going on here, beyond Revit. It could be outdated printer drivers, or something like that. I just tested on our system (2009 web update 1). Solid Black filled regions print without a problem.
    Best of luck,
    Bryan
    100 Club Jos Arpink's Avatar
    2001-12
    Vancouver BC Canada
    129
    I am using the latest build and it is still broken. It was not an issue in 2008.
    Jos Arpink
    NavisWorks Moderator david.kingham's Avatar
    2004-07
    Fort Collins, CO
    1,329
    It was a bug in 2008, you have to print with raster. It IS fixed in 2009.
    2001-12
    Vancouver BC Canada
    129
    Thanks David...this is wierd. I have stepped out of the car, closed the door, walked around it 3 times, stepped back in, and triple checked my version/build numbers and am still seeing this issue in 2009, and not in 2008.
    I neglected to mention in my previous post that I am using Revit Structure 2009. I will contact Adesk support to see if they can duplicate. Stay tuned...
    Jos Arpink
    2004-07
    Fort Collins, CO
    1,329
    Hmm that's odd, just tried it in structure 09 and it works fine...is it just one family that does it or all of them?
    2007-11
    50
    This happens in any nested family with an annotation symbol family inside of a model family (such as an exit sign, or elec. fixture).
    2005-11
    Minneapolis, MN
    14
    I have tested this in Revit Arch 2009 (Web Update 1) and it still does not plot filled regions properly (only the outline shows) with vector processing. I've attached my test file as an example. I just stopped making families like this...who needs data symbols anyways?!
    Andy
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Quote Originally Posted by andrewjohnson97 View Post
    Andy
    It worked fine here, printing your file to PDF. See attached. (RAC 2009)
    Andre Carvalho
  1. Replies: 10
    Last Post: 2010-03-11, 11:49 AM
  2. Solid filled regions print always black
    By stephanschneller in forum Revit Architecture - General
    Last Post: 2009-11-26, 12:31 PM
  3. "French horn" or "Sea shell" 3D solid
    By wpeacock in forum AutoCAD 3D (2006 or below)
    Last Post: 2005-10-10, 04:21 PM
  4. Any "filled region" resolution?
    By mikefields27 in forum Revit Architecture - General
    Last Post: 2005-01-06, 07:38 PM
  5. "White" filled regions print Black???
    By jabberwoki in forum Revit Architecture - General
    Last Post: 2004-06-30, 07:00 PM
