Results 1 to 10 of 10
Thread: Stepped retaining wall?
    2004-06
    Memphis TN area
    6,700
    Default Stepped retaining wall?
    Anybody have tips for modeling a stepped site retaining wall? I may end up just doing a separate wall for each course of block, since the ends of each course will end in different places, depending upon the grading.
    AERC, PLLC
    Hernando, Mississippi
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,532
    Default Re: Stepped retaining wall?
    why not just edit the wall profile?
    Steve
    2004-06
    Memphis TN area
    6,700
    Well each block course steps back a bit. I suppose I could do an in-place blend with the top wall surface pushed back from the bottom wall surface, and then cut the ends with voids.
    I was trying be able to do it entirely in plan, though.
    AERC, PLLC
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Quote Originally Posted by patricks View Post
    Patrick,
    If you want to do it in plan and still be able to edit the profile of the wall later to make it respect the grading, you could use a stacked wall. You know, you can play with the walls offset and editing the profile of the stacked wall will "cut" all at once.
    Andre Carvalho
    2006-01
    4,516
    Make a stacked wall using a Basic wall type that is CMU, and make each wall in the stacked wall one block tall, with offsets in the definition of the Stacked wall?
    The above post is by a user not frequenting the site. Questions regarding post:
    Send to: aaron@aaronmaller.com (include text of post). Thanks.
    2004-06
    Memphis TN area
    6,700
    wow, can you do a stacked wall with that many separate wall "pieces"?
    I will definitely give that a try.
    AERC, PLLC
    2004-06
    Memphis TN area
    6,700
    Works great.
    Only problem is all the lines visible in plan at each course (stepped back 2") makes it look like a big black mass.
    AERC, PLLC
    2006-01
    4,516
    Yeah, i could see that... Although its "technically" right depending on how high your plan cut plane is set. Youll probably have to resport to some typical override or something at that location.
    Maybe put a plan region thats 6" off the ground around the wall so it only cuts one course?
    The only thing that could make the stacked wall approach a pain, is having to set one basic wall to variable. It that retaining wall needs to grow taler or shorter, youll need different definitions of stacked walls, as it wont let you make one shorter than the definition, and itll stop stepping after the definition hits the oroginal size. But, i cant think of any other way i would want stacked walls to function, so i love em the way they are, lol...
    Oh, except i wish they could attach bases and tops without attaching every basic wall, lol...
    2004-06
    Memphis TN area
    6,700
    I don't think a plan region would work, since the toposurface is 4-5 feet higher behind the wall than in front... hence the need for the wall in the first place.
    AERC, PLLC
    2006-01
    4,516
    LOL... Keep all the lines then, they should be there anyway.
  1. STEPPED WALL FOOTING
    By dotrvt in forum Revit Structure - General
    Last Post: 2011-10-25, 08:02 PM
  2. Railings on Retaining Wall
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2009-03-18, 12:24 AM
  3. Help for Stepped footing of wall
    By ljupadhyay in forum Revit Architecture - Families
    Last Post: 2008-01-22, 07:10 PM
  4. Stepped Wall Join
    By Exar Kun in forum Revit Architecture - General
    Last Post: 2005-04-11, 10:50 PM
  5. Retaining wall on slope?
    By Scott Hopkins in forum Revit Architecture - General
    Last Post: 2004-02-20, 07:12 PM
