Thread: RISER AND TREAD QUESTION
    2004-06
    133
    Default RISER AND TREAD QUESTION
    Will someone assist me in finding the parameter to set the "begin with a riser, end with riser in RA2009? For some reason it is not showing up in the element properties for stairs.
    Also, when setting the nosing length, is there a way to set the top tread nosing so that the nosing only extends beyond the front of the stringer and not the back?
    Thanks for the help
    2006-06
    Toronto, ON
    2,386
    Default Re: RISER AND TREAD QUESTION
    Quote Originally Posted by wse1 View Post
    It is there. See attached pictures. You just have to go to the stair properties and then select "Edit/New" to access it.
    Thanks for the help
    I couldn't understand your question. I think what you are asking is what Revit always does... Can you post an example?
    Unless you are talking about you just want the nosing on the front of the tread, then you have to go to the stair properties > Edit/new > Apply nosing profile : Front only.
    Andre Carvalho
  1. Multistory stairs tread/riser numbers
    Last Post: 2019-04-02, 08:31 AM
  2. Replies: 1
    Last Post: 2012-05-04, 06:50 PM
  3. How to join Tread and Riser?
    By craighowie in forum Revit Architecture - General
    Last Post: 2011-05-27, 10:24 AM
  4. Stair Tread question
    By billy007nh in forum Revit - Platform
    Last Post: 2011-05-13, 06:10 PM
  5. Stair top tread
    By rayf.141574 in forum Revit Architecture - General
    Last Post: 2007-06-22, 06:44 PM
