Results 1 to 7 of 7
Thread: Custom Electrical Symbol Text Style
    2008-06
    VA
    165
    Default Custom Electrical Symbol Text Style
    What's the best/easiest way to customize the text style and display of an electrical switch?
    Modify the existing blocks?
    Create one from scratch?
    I'd like to be able to make the text style annotative according to our company standard, right now in particular for our switches. After a decent amount of trial and error, and messing around with drawing scales etc. I was able to get it to work, but I would have to modify it for each individual switch style. Additionally, I'd like to modify the location of the subscript for the switches (e.g. 3-way switch).
    Any way to do this for multiple switches across the board, or am I stuck going through and modifying each one individually?
    Brad
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,829
    Default Re: Custom Electrical Symbol Text Style
    FWIW, I chose to eliminate the text (just the "S") and replace it with a polyline that mimics the "text". That way text style changes won't affect our light switches.
    And we use our own device styles, not the OOTB ones.
    R. Robert Bell
    Design Technology Manager
    S P A R L I N G
    Opinions expressed are mine alone and do not reflect the views of Sparling.
    2003-10
    San Francisco CA
    1,190
    Quote Originally Posted by bradg View Post
    Brad
    Hi Brad,
    I'm assuming you are talking about electrical devices. If you are, you can create the switch block and a text block and then use both of them in your device style. This way once you have one the looks/acts like you want then all you have to do is copy the device style, rename it, and change the text block.
    Hope this makes sense, if not, post back and I'll have some 'splainin' to do.
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    2008-06
    VA
    165
    Thanks Scott,
    I kind of follow what you're saying, but you may need to go into a bit more detail. I'm not an electrical guy, so most of the stuff is Greek to me, but here's what we'd like to do:
    We'd like to modify the Electrical symbols (we've been dealing with mostly Switches for now) so that they reflect the text style our company uses (simplex). For the switches, the big S is fine as the standard default text style, but we'd like the subscript font to display as simplex. There are also some switches we use that are not included in the OOTB content (that we can find at least), such as subscripts a, b, V, etc. Just to clarify, I'm only talking about the plan view display, I've got no problem with re-using the modelspace views of the switches (or eliminating them all together).
    Whether or not it's easiest to create these symbols from scratch, or if it's better to just modify the OOTB symbols, I'm not sure, that's where I'm hoping to get some input.
    Additionally, I'd like to try and make the entire symbol/device annotative, so we don't have to have 4 different blocks depending on what scale we're using.
    Finally, I haven't done much with the electrical portion of AMEP, so I don't quite know what I'm talking about, but I'd like whetever custom symbols/devices we create to behave the same way that the OOTB ones do (connections, properties, etc.)
    2001-08
    Dallas TX USA
    5,829
    Devices are annotative when they have the "Use Annotation Scale" option selected in the Views tab of the device style.
    R. Robert Bell
    S P A R L I N G
    2008-06
    VA
    165
    Quote Originally Posted by RobertB View Post
    Thanks Robert, I had forgotten about this setting.
    However, when I activate it, the device text resizes based on the current Annotation Scale and the Annotation Plot Size (accessible in the Drawing Setup). I can get it to display correctly by messing around with the text scale or Annotation Scale before creating the block, but it's kind of a pain and prone to error.
    Any recommendations on how to get them to be annotative at the right heights?
    Brad
    2001-08
    Dallas TX USA
    5,829
    Content that is targeted for annotative-based objects need to be based on a 1-unit height. For example:
    You want a piece of text to be 3/32 plotted. So you create a block where the height of the text is 1 unit. If you want a box around the text to be 1/4 on each side, the actual size of the box will need to be 2.666 units (2.6666 * 0.9375 = 0.25) Then, in Drawing Setup, you set the text height to 3/32" and the scale of the drawing to the appropriate value (let's use 1'-0"=1'-0").
    That annotation-based device then ought to have the correct dimensions.
    R. Robert Bell
    S P A R L I N G
  1. Electrical Motor Schedule/Symbol
    By karlb in forum Revit MEP - General
    Last Post: 2009-07-21, 01:14 AM
  2. Electrical Symbol Display 2D vs 3D
    By Liamnacuac in forum Revit MEP - General
    Last Post: 2008-10-31, 05:36 PM
  3. Electrical Schematic Symbol to Device
    By Binu Mathew in forum AMEP General
    Last Post: 2007-02-05, 03:52 AM
  4. Electrical symbol line weights
    By tomdbiggsmail-retail in forum Revit Architecture - General
    Last Post: 2006-05-12, 12:24 AM
