We are having a problem of late with some of our Mtext, it seems that the actual size is smaller than the nominated size.
On further inspection in the properties window we have found that the actual contents has some formatting in it: example {\H0.5x;door} I know that it actually means that the text hight will be scaled down 50%.
My question is, apart from the obvious that someone has manually gone around and done it. Could there be another way, without the user knowing that this has happened.
It is in multiple drawings across multiple projects.
Any Insight would be appreciated.
