Thread: Bevel ended glass fins; as curtain wall mullion?
    2001-12
    1,713
    Default Bevel ended glass fins; as curtain wall mullion?
    We have a curtain system inserted in a precast "shadow box" with beveled sides, and then a series of horizontal glass fins at the horizontal mullions. Currently this is modeled as a series of nested curtain walls to make design changes easier. However, we want the end of the fins to bevel to match the shadowbox, and as far I can tell there is just no way to do this with the overly simplistic curtain wall mullion. Hopefully I am wrong, and i can cut the ends of a mullion at an angle? Or is my best course of action a series of 2 point families?
    Gordon
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Default Re: Bevel ended glass fins; as curtain wall mullion?
    Hi Gordon,
    Let me see if I understood: Your fins are modeled as mullions and you want them to bevel with the shadow box?
    If yes, see if my idea works for you: Instead of creating the fins as mullions, model them as part of the curtain panel, then you can do whatever you want in terms of beveling.
    See the example attached.
    Andre Carvalho
  1. Curtain wall Mullion help
    By cadmaster77 in forum Revit Architecture - General
    Last Post: 2010-06-15, 08:22 PM
  2. Curtain Wall Mullion Tag
    By rjcoolpix880 in forum Revit Architecture - General
    Last Post: 2009-12-17, 06:43 PM
  3. Curtain wall mullion
    By crispin.schurr in forum Revit Architecture - Families
    Last Post: 2007-12-06, 10:11 PM
  4. T Mullion in Curtain Wall
    By boofredlay in forum Revit Architecture - Families
    Last Post: 2007-03-02, 03:46 AM
  5. curtain wall mullion - cuting curtain panels
    By janunson in forum Revit Architecture - Families
    Last Post: 2006-11-02, 08:24 PM
