Results 1 to 7 of 7
Thread: circle and center marks
    2004-08
    137
    Angry circle and center marks
    how can i get a center mark with the + in the center. right now I just get one big + and no breaks at the + it all just blends in. When I don dimcen cad only wants the size of the +. I tried to do <0 but it wont take it.
    0,0,0 The Origin
    8,570
    Default Re: circle and center marks
    Have you tried setting DIMCEN manually? A value of 1 should be a good starting point.
    2004-08
    137
    how us that done?
    0,0,0 The Origin
    8,570
    Type - DIMCEN [enter] 1 [enter]. (sometimes changes made in the style manager do not take)
    Then make a new diametral dimension. If you like the result, open dim style manager (ddim) and right-click "<style overrides>" and pick "Save to current style". That will fix the current style only.
    BTW, please read the forum notice.
    2004-08
    137
    Thumbs up Re: circle and center marks
    Found out too, that if style manager in the tab- fine tuning has the "Draw dim line between ext lines" box selected the -1or what ever number is a (-), will not work to give center lines.
    I was doing -1 and it just wasnt working, that's why I asked, "How do you do dimcen". But then I opened a brand new file and put a circle went to dimcen, did -1 clicked on the circle and wham, there was my centerline. So I just went tab per tab and from the old file to the new file and that's when I saw the Fine Tuning tab. I have spent 1 week on this. Worth my time though.
    0,0,0 The Origin
    8,570
    Thanks for the feedback.
    I never force lines between extension lines so I didn't know it had that effect (mind you, I never let the dimension create the centre-mark either - I draw true centrelines).
    2013-07
    Center marks in circles take way too much time. What I would do is create a block consisting of a circle with a 1 unit diameter (on layer zero, everything 'bylayer'). Then put the center mark inside the circle exactly as you want it on the dim layer. When you want to draw a circle, insert the block, scale to the diameter of the circle you want and explode it. Now you have a circle with perfect center mark every time.
  1. Routine to draw annotative center marks
    By jpcadconsulting347236 in forum AutoLISP
    Last Post: 2014-04-08, 06:10 PM
  2. 2012: Center marks don't scale annotatively?
    By chuck_cantieny in forum AutoCAD General
    Last Post: 2011-10-07, 06:58 AM
  3. Center marks that are intelegent
    By chuck_cantieny in forum AutoCAD Wish List
    Last Post: 2011-10-06, 04:48 PM
  4. Center Marks to have Object Intelligence
    Last Post: 2008-05-27, 09:25 PM
  5. Resize Center Marks According to Hole Size
    Last Post: 2006-08-31, 04:02 AM
